Looking for wheel center caps
Posted: Mon Oct 05, 2015 9:25 am
by lawoman301
I have searched all the GM parts online sites! Does anyone know where I can find them?
I believe its OEM part #20835338.
Re: Looking for wheel center caps
Posted: Mon Oct 05, 2015 10:03 am
by vibrologist
I bought a used one from these guys:
http://www.centercaps.net/
It was clean, had minor scratches and was a bit dull (wax it). It looks definitely better than a gaping hole.
Posted: Mon Oct 05, 2015 7:39 pm
by trb
Ebay should have some, but they will likely be more expensive. I know someone on here has the older style black Pontiac center caps on their 09 model, so that is also a consideration. I find those at the pick a part quite often and have an extra set somewhere.
Posted: Tue Oct 06, 2015 6:15 pm
by Derf
If you do not have a lead at a local parts yard, would 2nd trying ebay. If the finish is an issue, take the replacement and your Vibe's center caps, wet sand them with 2000 grit or finer then re-clearcoat them. The factory finish seems to dull, as long as the replacement is not gouged, minimal effort will get you a matched set.
