2009 1.8L valve clatter
Posted: Tue Sep 29, 2015 5:31 am
by beemerphile1
This started after my last oil change about two months ago. It may have been happening before the oil change but I didn't notice. On every start of the cold engine it has a bad valve clatter for maybe two seconds and then all sounds normal.
This issue suddenly appeared. I don't see how an oil change could cause this.
Crankcase is full with 5w20 oil and after a couple weeks of clatter I added a dose of Seafoam to the oil. Now several weeks and thousands of miles the clatter is still there.
The sound is similar to old technology engines that after lots of wear would have hydraulic lifters collapse.
The 1.8L engine is only at a little over 60,000 miles.
Re: 2009 1.8L valve clatter
Posted: Tue Sep 29, 2015 5:37 am
by gtv237
It's the variable valve timing controller on the intake side. If it stops in a certain position it can leak all the oil out of it and it just makes noise until oil reaches it again. No damage is being done it's just an annoying noise. It's a pretty pricey repair as well. Over $1000 at the dealer and around $400 if you do it yourself.
