This started after my last oil change about two months ago. It may have been happening before the oil change but I didn't notice. On every start of the cold engine it has a bad valve clatter for maybe two seconds and then all sounds normal.
This issue suddenly appeared. I don't see how an oil change could cause this.
Crankcase is full with 5w20 oil and after a couple weeks of clatter I added a dose of Seafoam to the oil. Now several weeks and thousands of miles the clatter is still there.
The sound is similar to old technology engines that after lots of wear would have hydraulic lifters collapse.
The 1.8L engine is only at a little over 60,000 miles.
