OEM Toyota Remote Start?
Posted: Sat Sep 19, 2015 12:22 pm
by goodvibes05
Has anyone installed this?
http://www.toyotapart.com/PT398-12090.html
looking for a remote start system for the winter. Its kind of pricey but I thought it would better integrate into the electrical system because it is OEM. Also it would be nice not to carry around another fob for the remote start.
Re: OEM Toyota Remote Start?
Posted: Sat Sep 19, 2015 9:52 pm
by ctgottapee
Has this been posted before?
Would be nice but install procedures would likely be needed
Posted: Sun Sep 20, 2015 2:22 pm
by goodvibes05
I looked to see if it had been posted before, couldn't find anything.
I did stumble on the dealer? installation directions for this system as well.
They can be found here: http://www.trdsparks.com/install/PT398-12090inst.pdf
It does look fairly complex, might need to get this done at a shop if I decide to go ahead and get this one.
Posted: Tue Oct 13, 2015 7:35 pm
by ctgottapee
Looking more into this, it appears the OEM system is crippled.
If you check the install sheet towards the bottom of the system tests, basically anything you do (Unlock, open door, use key to unlock, put key in ignition) will shut off the car. So you can remote start, but then always have to restart as you enter which is fairly ridiculous.
For the high price, an aftermarket system will not have that silliness, and will greatly upgrade the range of the remote.
Posted: Thu Oct 15, 2015 7:17 am
by goodvibes05
Ah very good catch! Yeah you can get an aftermarket system that does more for a fraction of the price, definitely going that route. Bummer they designed the OEM system that way... :(
Posted: Fri Oct 16, 2015 2:01 am
by SlammedNiss
Yea, I would definitely steer clear of the OEM remote start. Aftermarket would be a much better choice.
