2003 Vibe GT Replacement Engine
Posted: Mon Aug 31, 2015 12:11 pm
by gaconn
I have a 2003 Pontiac Vibe GT and the engine needs replacement. It needs a 2ZZGE engine and I have found a wrecked 2006 Pontiac Vibe GT?
Is there any difference between the 2003 2ZZGE and the 2006 2ZZGE? Thanks.
Re: 2003 Vibe GT Replacement Engine
Posted: Mon Aug 31, 2015 1:59 pm
by trb
http://www.car-part.com shows that all 2ZZ engines from 03-06 are interchangeable, Vibe and Matrix. There are several 06 motors on the website when you do a nationwide search. They use the Hollander Interchange manual that all salvage yards use. The main differences were in the ECU related to the lift points I believe. But I'm sure someone else on here can confirm, or check with www.monkeywrenchracing.com as they know a lot about these motors.
Good luck!
Posted: Mon Aug 31, 2015 4:10 pm
by Salsa Guy
TRB has it right and you can add Corolla XRS to the list of donors cars. The exhaust header would be different on the 04+ because of the smog pump I believe. You should just use the one off your engine.
Posted: Tue Sep 01, 2015 7:25 am
by gaconn
I appreciate the responses. I spoke with monkey wrench and they said that apart from air-induction that the 2006 would fit in a 2003 GT vehicle.
