LED Interior Light Mods
Posted: Thu Aug 27, 2015 5:40 am
The interior lighting in my '07 Base was not as good as I wanted it to be so I started messing around.
Picked up some leds from Princess Auto and went at it.
Modified the dome fixtures to add leds, and a lead out. Burned the existing bulb out and used it by soldering the led leads to the caps. Double back tape holding the led in the fixture.
Wanted more light up front so went with these guys.
This required removal of the headliner.
Fixtures, handles, and visors out.
Mostly down, have to remove wires taped to the back of the liner.
Taped the wires to the roof, added lead to front.
Forgot about the camera until she was done. Basically drilled three holes, carefully with a spade bit no less, lifted the liner back in place ensuring wires were fished through, wired, tested, put everything back up. Finished product.
Much brighter inside and a whiter light than the old yellowish incandescent. The new fronts are run off the middle fixture switch for door-off-on. Some glare from the new fronts as you can see the diodes from the seats. May try to fab a little shade fixture. All in all much improved interior lighting. Trickiest part doing the headliner was finding out, through a GenVibe post, the removal method for the visor clips. Turn 90 degrees and pull. Didn't know that one.
Fever
Fever
