LED bulbs for dome & cargo area lights?
Posted: Wed Aug 26, 2015 11:17 am
by jake75
Anyone ever come upon LED replacements for the dome and cargo area lights?
Twice I have left the cargo area light on - once completely drained the battery.
Thought LED would not draw much current sparing the battery.
Re: LED bulbs for dome & cargo area lights?
Posted: Thu Aug 27, 2015 5:55 am
by Fever
My Princess Auto has direct led replacement bulbs for the dome lights. Philips brand $10 each, single diode. Mine were the shorter of the two festooned styles. However, I went a cheaper route and modded 2X3 diode panels ($3) in the fixture. I just made a thread about it here, check it out.
Posted: Thu Aug 27, 2015 6:41 am
by ehoff121
I used a panel of SMD LEDs for both dome lights, similar to this listing on ebay:
http://www.ebay.com/itm/24-SMD-T10-12V- ... c2&vxp=mtr
I did not purchase mine from this seller and purchase history doesn't go back far enough to find out who I bought them from.
There are square and round options available. You can also go with fewer LEDs or up to 48, but I wouldn't go with more than 24- too bright!
You can also find LED replacements for the map light.
Posted: Fri Aug 28, 2015 9:22 am
by Derf
Link to thread on interior lights. As you read the post, you get can see more options have been created, feston bulb, panel array etc. The small LED feston modules draw the least power, while the panel arrays draw more power while yielding more light.
viewtopic.php?f=28&t=37574&p=420305&hil ... md#p420305
Posted: Fri Aug 28, 2015 9:41 am
by jake75
I was under the mistaken assumption that there might just be an LED version of the existing bulb that could be easily swapped out, i.e. replace the OEM bulb with an LED counterpart.
Posted: Sat Aug 29, 2015 4:52 am
by Fever
jake75 wrote:I was under the mistaken assumption that there might just be an LED version of the existing bulb that could be easily swapped out, i.e. replace the OEM bulb with an LED counterpart.
As I posted earlier, Philips has direct replacement bulbs. LMGTFY: http://www.amazon.com/Philips-festoon-X ... B009NOZ5C2
Posted: Sat Aug 29, 2015 9:07 am
by jake75
That link got me to an Amazon page that warned "This does not fit your 2009 Pontiac Vibe. But it did have a feature that allowed me to find one that does fit [Pilot #3175]. It says for "Dome Light" - looks a little like a fuse with tapered ends like a Tepee. I will check to see if that is the same as used in the cargo area light. Were about $6 each - free prime shipping.
Posted: Sat Aug 29, 2015 12:35 pm
by Fever
jake75 wrote:That link got me to an Amazon page that warned "This does not fit your 2009 Pontiac Vibe. But it did have a feature that allowed me to find one that does fit [Pilot #3175]. It says for "Dome Light" - looks a little like a fuse with tapered ends like a Tepee. I will check to see if that is the same as used in the cargo area light. Were about $6 each - free prime shipping.
Okay, maybe the '09 model uses a different bulb than my '07. Sorry about that. However mine is the same as you described, 30mm long. Which is the style of the Philips one I linked. I'm sure the one you found will work.
Posted: Sat Aug 29, 2015 1:21 pm
by vibenvy
We have 5000k (bright white, no hint of blue) LED bulbs in all the interior lights of both our Vibes. The ones I got are direct bulb replacements. Plug and play. They are polarity sensitive though, so if you plug them in and they don’t light up, pull them out, turn them around and put them back in and they should work. No wiring or anything needed. I got them from v-LEDs.
I’m not sure about the light/s at the very front of the headliner above the rear view mirror since you have a Base that I know doesn’t have the same map light setup as our GTs do, but I used #194 bulbs in our map lights up front and #DE3175 / #30mm in the center and rear (cargo) overhead lights. Their prices have gone up since I bought all our LED bulbs a few years ago, but I am leery of buying ones on eBay. I prefer to have the backing of a company with a proven track record of quality products. You may also be able to find some good deals in their Closeout Section.
Super Bright LEDs is another reputable company to deal with and their prices are cheaper than v-LEDs. Here’s their selection of #194 bulbs and #DE3175 / #30mm bulbs. Sometimes you can find some deals in their Clearance Section.
Whatever bulb you end up getting, my only suggestion would be to get ones that have a 360* angle so you don’t get “hot spots”.
