wheel bearing replacement
Posted: Mon Aug 24, 2015 7:49 pm
by jwangelin
Hi,
Has anyone used a front wheel bearing adaptor as sold by harbor freight.
http://www.harborfreight.com/fwd-front- ... 66829.html
I had one side done at the garage and am still feeling the financial pain from that. The other side is getting noisy and was wondering if this might make for a good weekend fix. Any suggestions would be appreciated.
Thanks in advance,
Jon
'06 vibe FWD 195,00 miles
Re: wheel bearing replacement
Posted: Tue Aug 25, 2015 3:37 am
by gtv237
If you had an impact it might be worth it. I still don't see how that took could pull the hub though. It looks like all it could do is maybe pull a bearing.
Posted: Tue Aug 25, 2015 6:07 am
by sideshowalan
Another cheaper option is to pull the hub yourself. Take a new bearing and the hub to a shop and have them just switch it out.
The bearing looks like a big pain to DIY.
Posted: Fri Sep 04, 2015 11:16 pm
by bowtieman427
Assuming this is for the front. I have that harbor freight tool that I use on all kinds of things, but not on the front bearing of the Vibe. I ended up taking my parts to the shop to have it pressed out and new one in. I got the hub out with a socket and hammer. I understand getting the HF tool because the shop charges a lot. My bearings came apart and for some reason the HF tool would not work.
Posted: Fri Sep 04, 2015 11:21 pm
by bowtieman427
The tool should work here is a video showing how to take it out with the tool
https://www.youtube.com/watch?v=2IcUFGM0wWk
Posted: Tue Oct 13, 2015 7:34 pm
by Sinusoidal
I would be surprised if that kit would pull the bearing or reinstall it. I used a 20 ton press. I have a nice Snap-on puller and I doubt that would have worked either. The adapters from the kit are handy though. Also, the outer bearing race will stay. I cut mine off with a die grinder. Be careful not to cut too far. A nice grove and then a tap with a chisel knocked it right off.
Posted: Thu Oct 15, 2015 1:51 pm
by triz
I find it easier to replace the whole hub. But my experience has always been with a RWD. So I couldn't say how hard it is to do on a FWD.
Posted: Thu Oct 15, 2015 2:39 pm
by jayoldschool
I agree, don't bother with a tool to try and pull it out. Just take the spindle off, and press the bearing out. Easy, and done every day at shops.
