2006 pontiac vibe intermittent extended crank, hard start
Posted: Wed Aug 19, 2015 11:11 am
Hello.
My wife's 2006 Pontiac Vibe recently started to have an issue with intermittent extended crank and is often hard to start. It always starts, but one out of six times it will crank without start.
At first, not knowing what the issue could be, I had the alternator tested and it tested bad. I originally thought this was the problem.
I attempted to remove and replace the alternator, but the bottom mount bolt refused to give and I snapped two sockets on it. So I took it to a mechanic I know and trust and before replacing, he tested the alternator good with his test equipment. 14 volts going to alternator. So we left original alternator in. Two days later, same extended crank issue. I had the alternator tested at two different Autozones, both tests bad with 12.87 volts going to battery. So, I had the alternator changed, after bench checking the new one before installation. After installation, the car started fine. Again, two days later, extended crank with start on second attempt. I drove the car for a couple days and had one incident of extended crank. My wife again drove later and it extended cranked two times during her shopping excursion.
I again tested the alternator at one Autozone location bad, this time showing it was calling out the generator. The Autozone guy wasn't happy with me testing it again, not to mention requesting him to bench check the original alternator that I still had in the box in the back seat, but I wanted to eliminate bad actors. So I left Autozone #1 being told my generator was bad. Not convinced, I went to Autozone #2 across town and had the test done again....this time, it tested good, supplying 14 volts.
I am convinced I have an intermittent issue with the charging system. I'm not convinced it has anything to do with the extended crank starts......but it may. Thoughts? Other reading I have done points to ECM/PCM or EFI fuse. Suggestions? Thoughts? Recommendations?
Borsheim1983
Borsheim1983
