FS: 1ZZ Parts for sale obo
HaZzArD
Post by HaZzArD »
I have some parts for sale mostly 1zz stuff unless stated otherwise. All prices are obo. Prices do not include shipping but depending on size of item you are interested in we can work something out. Sorry for low post count but I was mostly active on matrixowners under the same user name. On to the pictures:
Located: Orlando, FL
OEM 1zz short block & Crank - 93k miles - Will be deck & cleaned before shipping out - Perfect for someone who wants to build up a 1zz - $250 obo
ACT XTSS 1zz/2zz clutch - 1zz Fidanza flywheel - SOLD
1zz 79.5mm 8.8:1 Wiseco Pistons - Used - 5k miles - New Piston Rings & C-Clips - $400 obo
1zz turbokits.com partial turbo kit - Used - 15k miles - TKC turbo manifold - GT2871r BB turbo - TKC Downpipe - Oil/Coolant Lines - PTP turbo blankets & PTP exhaust wrap -$1000 obo
(Black silicone coupler not included)
Deatschwerks 440cc injectors 1zz/2zz - Used 15k miles - $200 obo
Built 1zz-fe '2.0L' Long block - Used 10,726 miles - $3,500 + Freight Shipping
Darton Sleeved 1zz-fe short block.
Crower Connecting Rods
82mm Wiseco Pistons - 8.8:1
Kings Main/Rod Bearings - STD size
Arp Main/Head Studs
Toyota OEM 1zz-fe Crank - Checked and journals polished
Block was decked, bored/honed, aligned honed (main journals) and cleaned before put together.
Head was ported on both Intake & Exhaust side
3 Angle Valve job
Crower Stage 2 FI Cams
MWR Valves, valve springs & retainers
Head was decked & cleaned before put back together
Passenger side trim piece:
Silver - $20
Flat black - $30
HVAC/Shifter trim piece - Flat black - $35
Deatschwerks 700cc Injectors 1zz/22 - New - $350 obo
Payment: Paypal
More pictures can be taken upon request.
HaZzArD
Re: FS: 1ZZ Parts for sale obo
Post by HaZzArD »
Start up video 'Warm' & More information about the engine in description - https://www.youtube.com/watch?v=KsI9YxNywDs
Start up video 'Cold' - https://www.youtube.com/watch?v=wjGSqNIgS9E
I made 315whp/275wtq with my turbo setup with this engine and never had any issues with it. Engine runs strong and did not burn a single drop of oil. No corners were cut on the engine build.
HaZzArD
Post by HaZzArD »
Lowered prices on some parts (minor). Prices are obo so send me offers for parts you interested.
Deatschwerks 700cc Injectors 1zz/2zz - New - $325 obo
Stock 1zz-fe short block & Oem Crank - Used - 93k miles - $100 + Shipping but will only be cleaned. or if you want both as-is - $50 + Shipping
79.5mm 8.8:1 Wiseco Pistons - Used 5k miles - Comes with new piston rings & C-clips - $375 obo
1zz Fidanza flywheel - ACT XTSS Clutch kit 1zz/2zz - SOLD
Turbokits.com Kit - 1zz TKC manifold, GT2871r turbo, TKC downpipe, Oil feed/return(-10AN), Coolant lines w/ stock coolant hoses so you don't have to cut yours to tap into the coolant line. PTP Turbo blankets & PTP Exhaust wrap. All together - $1200 obo
Bcredille52
Post by Bcredille52 »
I know it's been years since you posted about this,is there any chance you still have all of this?.
Bcredille52
