SRS Airbag Codes and "Airbag Sensing and Diagnostic Module" replacement
Posted: Sun Aug 16, 2015 6:46 pm
by GaryG92
So for as long as I can remember, my airbag readiness light has been on. When I got some recall work done, the dealership told me my Airbag sensing and diagnostic module was bad, but I didn't want to jump the gun and buy into their $600 estimate for the repair.
Today I pulled my airbag codes by jumping the OBD connecting. The codes I got are: 35, 37, 52, 53, and 54.
Does this sound like that sensing and diagnostic module is bad? I found a new GM part on eBay for 1/4 of the price GM quoted me. I might buy it, and I'd probably just change it out myself.
It's located under the shifter, right? What all do I need to remove to get to it?
I've looked in my Chilton's repair manual for all this info, but there's not much on any of the safety system.
Re: SRS Airbag Codes and "Airbag Sensing and Diagnostic Module" replacement
Posted: Mon Aug 17, 2015 6:44 am
by ImUrOBGYN
I have found you cant believe half the (removed) they say about the airbags, especially depending on the time frame of your questioning them. They're simply trying to save their asses money/time while this whole airbag recall fiasco continues. Personally, I had zero issues with airbags until I went in for their temp "fix" awhile back. Then my light came on, and they tried to tell me the same (removed). I'll be going back for the new airbag fix soon on the driver's side. If it's not fixed then, they can expect some phone calls to corporate. Guaranteed I pay for nothing when this is over. :twisted: Man, I hate GM (this isn't the only reason by FAR)
Posted: Mon Aug 17, 2015 7:23 am
by GaryG92
ImUrOBGYN wrote:I have found you cant believe half the (removed) they say about the airbags, especially depending on the time frame of your questioning them. They're simply trying to save their asses money/time while this whole airbag recall fiasco continues. Personally, I had zero issues with airbags until I went in for their temp "fix" awhile back. Then my light came on, and they tried to tell me the same (removed). I'll be going back for the new airbag fix soon on the driver's side. If it's not fixed then, they can expect some phone calls to corporate. Guaranteed I pay for nothing when this is over. :twisted: Man, I hate GM (this isn't the only reason by FAR)
Well I just pulled these codes myself. Seems crazy to have 5 codes. Idk what to do about all of them.
Posted: Mon Aug 17, 2015 11:26 am
by GaryG92
Got in touch with a company that does a lot of airbag work, module replacement and whatnot. Here's what they say the codes are:
35 - door side impact airbag sensor LH malfunction
37 - front air bag sensor LH malfunction
52 - short to battery power (12 volts) in P airbag or explosive module circuit
53 - open in P airbag or explosive module circuit
54 - open in passenger's airbag or explosive module circuit
Posted: Wed Aug 26, 2015 1:06 pm
by GaryG92
The first time I pulled these codes, I jumped the connector and then turned the car on (not the engine) and it gave me those 5 codes.
I decided to try again today, but instead I turned the car on, waited a little bit, and jumped the connector. This time I only got code 53.
Anyone have any experience with this stuff? I just want my airbags to function properly in case something were to happen.
