Interior cabin noise is loud!
Posted: Thu Aug 13, 2015 2:31 pm
by Gohan77
I have a 2009 AWD Vibe (77,500 miles) and has been a great car. But Since I have owned it I have noticed a slight rattling noise at or around 2000 RPM, especially going up a hill. Almost like it doesn't know what gear it wants to be in. So in order for me to stop the noise I either have to slow down or speed up so it shifts. Anyone experiencing this issue?
I have also noticed that the interior cabin noise is horrendous. Going over certain roads it gets even louder and more unbearable. I love the car, but is there a way I can reduce the cabin noise and make it a more comfortable car to be in?
Re: Interior cabin noise is loud!
Posted: Thu Aug 13, 2015 3:43 pm
by TreFatKids
I don't know about the rattling noise but for interior noise you could by some sound deadening material and put it under the carpet. Usually comes in a roll.
Posted: Sun Aug 16, 2015 4:49 pm
by jolt
For the interior noise you could pickup some cheap foam backed carpet from your local home improvement store. Cut to fit over the interior floor of the car and try it to see how much noise is reduced. The thicker the foam backing, the more noise it will absorb. The area I would do first is the rear as it is all plastic back there with very little sound control. Be careful of putting carpet under your pedals so your pedals do not get carpet cot in them (think gas pedal recall and the first thing that was blamed on).
The rattle noise at the same engine rpm, I would be checking all the shields under the car. Check all the exhaust shields and the gas tank shield. Sometimes just bending a shield at the right place will stiffen it up and stop the rattle. Look for bad exhaust hangers or exhaust that is to close to other parts and rubbing.
Posted: Tue Aug 18, 2015 1:43 pm
by Nasmfell
Gohan77 wrote:I have a 2009 AWD Vibe (77,500 miles) and has been a great car. But Since I have owned it I have noticed a slight rattling noise at or around 2000 RPM, especially going up a hill. Almost like it doesn't know what gear it wants to be in. So in order for me to stop the noise I either have to slow down or speed up so it shifts. Anyone experiencing this issue?
How loud are we talking? Hard to carry on a conversation or hear one talking?
Posted: Tue Aug 18, 2015 3:48 pm
by gtv237
As an automobile technician I drive every type of car out there and my vibe is on the quieter end on interior noise. Sounds like something may be wrong with yours.
Posted: Tue Aug 18, 2015 4:39 pm
by Gohan77
gtv237 wrote:As an automobile technician I drive every type of car out there and my vibe is on the quieter end on interior noise. Sounds like something may be wrong with yours.
How specific and helpful
Posted: Tue Aug 18, 2015 5:28 pm
by gtv237
Gohan77 wrote:gtv237 wrote:As an automobile technician I drive every type of car out there and my vibe is on the quieter end on interior noise. Sounds like something may be wrong with yours.
Thought that was the trend for this thread.
Posted: Wed Aug 19, 2015 7:33 am
by circuitsmith
Are you running tire pressure much above spec (32psi)?
That will increase noise.
How far down are the tires worn?
They let more road surface noise through as the tread gets thinner.
Posted: Wed Aug 19, 2015 8:22 am
by Gohan77
circuitsmith wrote:Are you running tire pressure much above spec (32psi)?
PSI is right at 32. the tires are fairly new still. atleast 75% tread.
Posted: Wed Aug 19, 2015 2:18 pm
by cptnsolo77
Oh wow I didnt know that higher tire pressure produced more road noise. I run my tire pressure at 37 psi. Im going to try 32 again. Thx for the tip. I always thought the vibe was pretty loud on the highway. Even with sound deadening on all doors, pass and driver floorboards its still noisy. I have learned to live with it since its such a great car with lots of other plusses.
