Best cold air intake for 07 vibe.
Posted: Tue Aug 04, 2015 6:42 pm
by Xebaxtien
Probably already asked many times but i was wondering what was the best cold air intake for a 07 vibe? This is the only ones i really found:
http://www.carid.com/2007-pontiac-vibe- ... 85831.html
http://www.carid.com/2007-pontiac-vibe- ... 84336.html
Also i was wondering if a air intake of a 07 matrix work on a 07 vibe?
http://www.autoanything.com/air-intakes ... air-intake
Thanks in advance
Re: Best cold air intake for 07 vibe.
Posted: Wed Aug 05, 2015 6:01 am
by TraumaForYou
Xebaxtien wrote:Probably already asked many times but i was wondering what was the best cold air intake for a 07 vibe? This is the only ones i really found:
Thanks in advance
To be honest i would hardly call those first two cold air intakes. I found one on ebay for the matrix that has worked perfectly with my 06 vibe. http://www.ebay.com/itm/Cold-Air-Intake ... dc&vxp=mtr
It goes all the way down behind the fog light.
Posted: Sat Aug 08, 2015 3:47 pm
by lannvouivre
The intakes for 2003-2004 Matrix, Corolla, and Vibe base are all the same. 06-08 intakes are the same on base trims as well. The Matrix XR has the same intake as the base and the same engine as well, it's just a base with pretty exterior bits.
The 2003 and 2004 intakes are different from the ones for 2006-2008.
EDIT: You don't need to spend big bucks on an intake unless you need a sticker saying it's emissions-safe and they actually check under the hood.
Posted: Mon Aug 10, 2015 3:04 pm
by Salsa Guy
Get a SRI, easier to install, maintain and the gains are the same. The big difference between the 03-04 and 05-08 is the valve cover breather port. On the 03-04 is built into the Throttle Body on the 05+ it's built into the intake hose. Many Used the 03-04 CAI/SRI on the 05+ by either adding a breather port to the intake or add a small breather filter to the breather hose ($10 at most Auto Part stores).
Posted: Tue Aug 18, 2015 11:59 am
by thebarber
Ebay intake + k&n filter
