TRD SUPERCHARGER FOR SALE - COMPLETE SET-UP
Posted: Mon Jul 20, 2015 4:11 pm
by vvtiDavid
Selling my TRD supercharger that was on my Vibe; for Matrixs, Vibes, Corollas, and with further modifications also for 8th gen Corollas and Celicas with the 1ZZ-FE engine.
This is probably the most ideal set-up you could do, because I choose to upgrade the fuel injectors instead of adding the 5th injector, so no need to cut your fuel line and it's easier to tune.
The tune was set-up for a Standard/Manual Transmission vehicle, so if you have a standard it's just a matter of Plug and Play, but if you have an automatic then I would say Tune it afterwards.
This packaged deal includes...
-TRD Supercharger and extra pulley
-Greddy Emanage Ultimate
-Harness to Plug in Greddy Emanage with Stock ECU
-DeatschWerks Fuel Injectors rated at 370 cc
-NGK Spark Plugs # BkR7EIX
-160 degree thermostat
-Dayco Belt #5060850
*in Good-Great condition, no cracks, no uneven wear
-Custom made steel gasket for Supercharger
-Brackets, bolts, and anything else that came with it when I got it I will send out as well.
$2200
EXTRAS not included, but can be
-AEM UEGO A/F ratio Gauge and wires $110
-Throttle Body Adapter for 05-08 vehicles $100
PM if interested,
Will ship to Canada and Lower 48 US states via UPS.
Paypal only
Re: TRD SUPERCHARGER FOR SALE - COMPLETE SET-UP
Posted: Mon Jul 20, 2015 4:15 pm
by vvtiDavid
I'm having trouble uploading pictures right now,
I'll try again later, or send em' via PM or e-mail.
And if someone could repost to Matrix Owners forum and Gen 9 Corolla,I'd appreciate that! :)
Posted: Mon Jul 20, 2015 6:24 pm
by lannvouivre
A tune will be required regardless because every engine has a different amount of wear and what-not.
The ECU of 03-04 Vibes is different from that of 05-08 due to the 05-08 being DBW and not DBC, so you need to swap around I think 4 wires if you are going to a different years bracket than this setup is for.
Posted: Mon Jul 20, 2015 7:09 pm
by vvtiDavid
There we go
Posted: Mon Jul 20, 2015 7:10 pm
by vvtiDavid
lannvouivre wrote:A tune will be required regardless because every engine has a different amount of wear and what-not.
Yea, makes sense
Thanks for the Information!
My set-up was an 05'
Posted: Mon Jul 20, 2015 8:35 pm
by lannvouivre
Everything is indeed there.
If you ran the 5th injector, I don't think you actually need to cut the line. It's plug and play. All you have to do is make a t-splice or two into one of the injectors so that the 5th gets power.
Posted: Tue Jul 21, 2015 1:44 am
by thebarber
location?
Posted: Tue Jul 21, 2015 6:34 am
by vvtiDavid
thebarber wrote:location?
Mississauga, On. near Brampton, ON
Posted: Thu Jul 23, 2015 6:41 am
by vvtiDavid
I want to stir more interest,
so price change to $2100.
and AEM UEGO A/F ratio Gauge and wires $100
-Throttle Body Adapter for 05-08 vehicles $75
Posted: Thu Jul 23, 2015 4:31 pm
by lannvouivre
I just remembered that the belt for the Vibe and the Matrix will be different. The Vibe has a different A/C system from the Toyotas, and the belt is a different length (presumably for this reason). Hope that's coherent, one of the foster kittens is obsessed with my monitors and the other is chewing my thumb as I type...
Posted: Mon Aug 03, 2015 7:39 am
by B14CK_H4WK
I'm the one who has been messaging you on kijiji. Definitely want to take this off your hands asap!!
Posted: Mon Aug 24, 2015 10:13 pm
by vvtiDavid
vvtiDavid wrote:Selling my TRD supercharger that was on my Vibe; for Matrixs, Vibes, Corollas, and with further modifications also for 8th gen Corollas and Celicas with the 1ZZ-FE engine.
$2200
PM if interested,
Paypal only
-DeatschWerks Fuel Injectors rated at 370 cc -SOLD
AEM UEGO A/F ratio Gauge and wires -SOLD
NEW PRICE- $1800 for the rest of the parts in a bundle
Posted: Tue Aug 25, 2015 5:51 pm
by vvtiDavid
Found 5th injector line, also included
Posted: Wed Aug 26, 2015 8:04 pm
by B14CK_H4WK
Sorry David. I ended up picking a SC off a corolla guy local actually.
Posted: Tue Sep 08, 2015 7:16 pm
by mikethepole
does this setup work with the GT model (2ZZGE engine) ?
I am located in the GTA
thanks
Posted: Wed Sep 09, 2015 12:47 am
by B14CK_H4WK
I believe that it only works on the 1ZZ-FE
Posted: Mon Sep 21, 2015 2:20 am
by lannvouivre
mikethepole wrote:does this setup work with the GT model (2ZZGE engine) ?
thanks
No. The 2ZZ is a completely different engine and so you would need a special adapter for the intake ports and probably one for the throttle body.
Posted: Mon Oct 05, 2015 10:34 pm
by oldelpaseo
Has it been sold ?
