Big Electrical problem
Posted: Mon Jul 06, 2015 10:32 am
Sorry for the long post as my first but my search is coming up almost empty. First let me tell you what I was doing when the electrical problem occurred.
I was replacing the A/c heater Blender motor. I had car running watched door close and bounce(would not shut off) I wanted to keep door in outside air circulation so I pulled the wire connector off the blender motor. THATS when all heck started....first the A/C blower motor turned off and I heard the A/C compressor clutch go off....I lost all dash lights and all gages along with the 110v inverter. The turn signals are gone along with the Power windows, the OBD check engine light and air bag light is on. I do have flashers, no turn signal. The good news is I can listen to the radio while I try to fix all the systems.........LOL
Anyway its 2007 vibe base 1.8. I have check all fuses(all good) under dash and under hood.....I did do a swap on a few relays that had duplicates under the hood and the relays over the glove box......so far no luck.
Stumped!!!!! any thoughts.
Thanks in advance
Thanks in advance
