Stumped by random misfire
Posted: Thu Jun 25, 2015 8:21 am
2003 base FWD 162k miles.
I bought this vibe a month ago. Ran fine, a little underpowered and some exhaust noise.
Started getting p0300 and p0301 p0302 p0303 p0304 and p0420 after couple days driving, can feel slight misfires at idle, sometimes a slight hesitation on initial acceleration
Took care of exhaust leak, shop put in a spacer and new donut gasket and that took care of loud exhaust but still get p0420 along with the misfire codes.
***Each time I've fixed / tried anything I have reset by disconnecting battery negative terminal for 20 mins.
First thing I did was replace plugs with the NGK laser iridiums - No change in symptoms.
Noticed intake manifold gasket was the black one, replaced it with orange from Toyota - no change.
Cleaned MAF twice - no change
Replaced air filter.
Replaced PCV - no change
Ran Techron thru a few tankfuls - no change
Checked battery and alternator at AutoZone, both test good. Cleaned battery terminals and replaced cruddy looking positive terminal.
Checked ground points with resistance setting on multimeter all read 0 ohms to ground at battery.
Pulled and inspected injectors, put back in with new O rings - no change.
If I pull any coil or injector connector while running idle gets worse so it's not any one cylinder that's causing it ???
Checked vacuum with gauge and all reads normal from what I can tell.
Pulled crankshaft position sensor and cleaned , didn't know how to test?
Pulled OCV valve (it looks new from prev owner) it had oil on it so it's good?
Tried to pull VVT-I filter but too tight without taking intake back off to get some room but it's hardly that causing misfires???
I know injectors could possibly be clogged, coils could be bad but can't really afford to just throw parts at it to try and fix it. I have a OBD scan tool ordered in the mail and will be able to get into more in depth analysis like fuel trims etc once I have that.
I have searched and searched all over internet for answers/ideas and having tried the more obvious stuff I'm pretty stumped on this but need to troubleshoot some more as I can't really afford to just drop it at a shop right now.
Any pointers from anyone??? I need to pass inspection to get registered etc
