power window regulator
Posted: Sun May 31, 2015 5:05 pm
by GOF
Just got a call from my wife's brother. Nice guy. But mechanically dangerous to himself and others.
So he tells me that his wife's 2003 Vibe has a problem with the drivers door window. Says it is "off the track". Not having had one of these apart I want to say it needs a regulator. So my question is, should I order a regulator? Or is there something else that can fail in these windows?
Re: power window regulator
Posted: Sun May 31, 2015 7:21 pm
by trb
There was a recall on the window bolts that attached the window to the regulator since the original ones failed quite often. It is possible that the recall was never done and the bolts failed, causing the issue. Or maybe they failed even after the repair. Something to check on before spending any money on it.
http://www-odi.nhtsa.dot.gov/cars/probl ... mmary=true
Posted: Mon Jun 01, 2015 4:55 am
by sideshowalan
Another common problem is the bracket that bolts to the regulator could come unglued from the window.
Have to take the door panel off and look around to know for sure.
If that's the case, it's fixable by removing the window and gluing the bracket back in place w/ some gorilla glue and a clamp.
Posted: Tue Jun 02, 2015 5:09 pm
by GOF
Thanks guys. Things to check before I order anything.
Posted: Sat Jun 06, 2015 6:23 pm
by GOF
So I went and checked this out today. Seems that the regulator is mangled. Twisted like a pretzel. I guess that's what happens when you keep trying to force a frozen window to open. :roll:
Posted: Mon Jun 08, 2015 4:13 pm
by lannvouivre
GOF wrote:So I went and checked this out today. Seems that the regulator is mangled. Twisted like a pretzel. I guess that's what happens when you keep trying to horse a frozen window to open. :roll:
It's not moving because you're not forcing it hard enough!
Posted: Mon Jun 08, 2015 5:23 pm
by GOF
Oh crap! Is that all?
