				Volume Knob Not Working
				Posted: Fri May 22, 2015 5:18 am
				by newt
				I just bought a 2010 Vibe and the only thing wrong with it was that the volume/power knob doesn't turn up or down, unless I push it to the left and slowly turn it, and even then it's not really working all that easy.
I'm happy with the factory stereo, so in order to not change the whole deck unit, is there a way to replace or fix this solitary problem?
I tried to pull out the knob and it doesn't.
				Re: Volume Knob Not Working
				Posted: Fri May 22, 2015 6:20 am
				by gtv237
				The knobs break all the time. There's a lip on the bottom so it doesn't pull straight out. You have to take the faceplate off and slide it out.
				Posted: Fri May 22, 2015 1:22 pm
				by newt
				Thanks. I ended up buying an aftermarket deck because I needed Bluetooth anyway.
Now the deck I got is XM Radio ready.
http://www.kenwood.com/ca/car/receiver/kdc-bt562u/
Do I need to buy the adapter (i.e. SXV300V1) that I install behind the deck and do I need to install the antenna, or can I use the Vibe's existing XM radio wires/connection to make it all work?
				Posted: Fri May 22, 2015 6:11 pm
Dang.  I was getting ready to ship you out some knobs
   Oh well, seeing how you replaced the HU I guess you won't be needing the knobs. Lots of topics on replacing the knobs on the 09-10 Vibe radios here on GenVibe.  Post pics of your Vibe soon.
				Posted: Sat May 23, 2015 1:56 am
				by newt
You know, after researching more last night I decided to keep the head unit,
so I'd LOVE to have the knobs, if the offer still stands.
Just sent you a message...
The reason I changed my mind was that I'd lose the integration of the look on the dash, and then getting XM Radio afterwards would be a pain.
I think I can just use my phone as a GPS and use handsfree on it.
Also the bottom line is that I just bought the car, so I'm pretty strapped for cash.
				Posted: Mon May 25, 2015 7:26 am
				by vibenvy
				Here's a
how-to thread for replacing the broken radio knobs.
As tpollauf said, start a thread in the Vibe Lounge Forum introducing yourself and be sure to post some pictures of your "new" Vibe as we love pictures around here!
				Posted: Sun Jun 14, 2015 7:42 am
				Newt.  Any update on the radio repairs? Just want to make sure you received the knobs that I sent you and hope the repair was a success
				Posted: Sun Jun 14, 2015 8:35 am
				by jake75
				Two things Toyota should have fixed years ago in response to many complaints.  1. This defective radio knob.  2. The defective gear on the on the motor that opens/closes the recirculation box.  These issues don't just plague Vibe and Matrix, but also Corolla and probably other Toyoto models.  One would think Toyota would place more value on their reputation.
