Surprise When Replacing Front Right CV Axle
Posted: Sat May 09, 2015 10:58 am
by Megladon7
I'm replacing the front right CV Axle (half shaft, half axle, whatever else you can think of to call it), on my '03 FWD 5-speed manual, ABS equipped Vibe. Had a little trouble getting the shaft out of the transmission, used a pry bar and out it came....along with copious amounts of fluid. Was NOT expecting that!
I do something wrong? HELP!
Re: Surprise When Replacing Front Right CV Axle
Posted: Sat May 09, 2015 11:18 am
by kumquat
The service manual for that car says to drain the transaxle and transfer case before removing the shaft, so I think you're OK. Just be sure to fill it back up and inspect for leaks once everything is back together.
Posted: Sat May 09, 2015 11:35 am
by gtv237
Yup that's totally normal. The fluid level is slightly higher than the hole the cv goes into. Just make sure you fill it back up. Put a little bit in and then drive it and check the level again. Don't just fill it up and assume it's full. You have to drive it before you get a true reading.
Posted: Sat May 09, 2015 2:53 pm
by Megladon7
Will do.
Thanks guys, just glad I wasn't under the flow when I pulled the axle!
Posted: Sat May 09, 2015 5:02 pm
by gtv237
Megladon7 wrote:Will do.
Yeah that's definitely a good thing.
Just noticed that you have the manual transmission. The fill procedure for that is to add fluid at the fill plug until it starts coming back out. That's when you know it's full.
Posted: Mon May 11, 2015 12:37 am
by lannvouivre
I pulled mine without draining it once just to see how much would leak out for laughs. It will also pour out if you install the axle seal wrong
Posted: Mon May 11, 2015 1:40 pm
by Megladon7
I was checking the old axle compared to my new one. The old one has a rubber donut clamped on the shaft between the boots. The new one does not.
What is it and do I need it?
Thanks in advance folks....
Posted: Mon May 11, 2015 5:03 pm
by gtv237
Megladon7 wrote:I was checking the old axle compared to my new one. The old one has a rubber donut clamped on the shaft between the boots. The new one does not.
It's a vibration dampener. It's not really necessary. Technically speaking it actually slightly imbalances the axle but it absorbs a very small amount of vibration to make things slightly more smooth. Newer cars have lumps of rubber on everything. Exhaust, motor mounts, brake calipers, etc. Its just extra weight to me but to each his own. I replaced my cv axle several months ago and I couldn't tell any difference.
Posted: Tue May 12, 2015 6:36 am
by Megladon7
O'Reilly guys tried to tell me that these new (actually re-maned) Axles are balanced better so they don't need the damper. Of course that's a bunch of horse hockey, but I'm installing the one w/o a damper anyway.
