Magnaflow cat converter and catback system and O2 sensor question
Posted: Sat May 09, 2015 4:54 am
I've been throwing a P0420 code lately on my base model 2003 FWD with ~148,000 miles. I can drive around town without throwing it but get out on the highway at 75mph for an hour or more and the check engine light comes on and it's the same code. I'm guessing my catalytic converter is failing since at higher rpm's for extended times, the cat would get hotter? Anyway, been looking at the Magnaflow catalytic converters since I've been told they have better flow than OEM. Anyone been down this road before? I am seeing 2 different part numbers. 1 looks like it is just the catalytic converter without the header flange mount or trailing pipe with the O2 sensor mount:
http://www.magnaflow.com/02catalytic_co ... rsal=51205
The other part number looks like it has from the flange mount back and includes the resonator???
http://www.magnaflow.com/02catalytic_co ... tfit=49461
Then looking ahead, I'm thinking the exhaust might not be too far behind and see the Magnaflow catback system has a resonator included?
http://www.magnaflow.com/02product/disp ... mber=15759
Also wondering about replacing the O2 sensors while I'm at it? Think I read on here that there are a couple of them to replace?
