No fuel
Posted: Wed May 06, 2015 5:52 pm
by Rockett03
I have a 03 vibe base model. I just put a 2zz engine, transmission, and ecu in from a 04 vibe gt (the ecu is from a different 04 gt than the engine transmission). My fuel pump ins't turning on and I can't figure out why. I have been looking at wiring diagrams and have gone through and check all the fuses and relays but maybe I missed some? Or maybe hooked a plug in wrong when putting the engine in? I have looked over everything I can think of so any help would be great!!!
Re: No fuel
Posted: Mon May 11, 2015 5:40 pm
by gtv237
Not quite sure how toyota does things during this era but maybe the ecm has to be linked with the bcm? Do you have a signal at the pump itself? I can provide you with troubleshooting sheets and wiring diagrams. Just let me know if you still need 'em!
Re: No fuel
Posted: Tue May 12, 2015 1:14 am
by lannvouivre
When you connect a scanner, are you getting communication with the ECU? Have you rechecked all wires and connectors?
Re: No fuel
Posted: Wed May 13, 2015 11:45 am
by Rockett03
I'm not sure what the eve and bcm are... I do not have any power at the pump. Any sheets or diagrams would be great!!
I don't have a scanner but that's going to be my next step. Ive checked the plugs going to the ecu.. Is there a plug in the engine compartment I would have disconnected involving the fuel pump?
