Aggravated ac
Posted: Fri May 01, 2015 1:33 pm
Old school mechanic with ac how to knowledge is totally baffled by this, bought the vibe new (ordered for my wife) black 2009 gt with all the bells n whistles, in late 2010 wifey got sick and in 2011 decided to quit driving after sitting at a stop sign for 11 minutes waiting for it to turn green. That's no joke. On to the issue
Put the vibe in storage for about a year
Got the vibe out one day to run it around the block, ac ice cold.
Put back in storage for another year until my oldest daughter wanted to use it, wanted to help my daughter but wanted limited miles so I let some freon out in my ac recovery unit until it quit blowing cold, daughter drove it for a couple months then back in storage it went, on to 2015 when after my ram died we decided to get it out and drive it.
Ac little green lite does not come on on knob,
Compressor must be internal clutch design as there is no old style clutch on it.
There is no low pressure switch unless it's a dual switch on the high pressure line,
There is no relay, now where to be found,
Fuse shows good as it is on the same as the rear window defrost and it's fine
Static pressure reads 85 psi on the low side with vehicle running and does no change,
Fan does not come on when ac button pushed, engine idle does not increase.
So here ya go fellas as I am stumped, thanks in advance for all that helps.
