				painting aftermarket parts
				Posted: Sun Aug 17, 2003 7:25 am
				by slickshoes
				hey,i noticed on gm's site that the sport package is not available in all colors like neptune*my vibes color* and was wondering where i could get these parts painted the same color as my vibe.
				Re: painting aftermarket parts (slickshoes)
				Posted: Sun Aug 17, 2003 10:08 am
				by meathead333
				id imagine any autobody shop that knew how the paint codes worked
				Posted: Mon Aug 18, 2003 1:03 pm
				by AKLGT
				i believe you can order the kit primered. any body shop or paint shop can paint them. will probably cost some money tho. automotive paint is expensive.
				Re: painting aftermarket parts (trdvibe)
				Posted: Fri Aug 22, 2003 2:14 pm
				by Jethro
				quote:automotive paint is expensive.  Apparently it's not cheaper in large quantities either ... NUMMI can only afford one THIN coat on these Vibes.
				Posted: Fri Aug 22, 2003 3:22 pm
				by engine1
				If you tell me your paint code(look on the sticker in the glove box, there will be a code at the bottom left that starts WA-**** BC/CC) I can give you the equivilent PPG code and some one in your area should be able to mix a pint of a DAR Arcrylic Enamel! If you want I can e-mail the formula directly to you, and you could take it to a body shop that uses PPG paint they could mix it for you too. Where I work we can even put it in a spray can with some on the side for touch ups, someone where you live may be able to do the same!
				Re: painting aftermarket parts (Jethro)
				Posted: Sat Aug 23, 2003 6:43 am
				by AKLGT
				quote:automotive paint is expensive.  Apparently it's not cheaper in large quantities either ... NUMMI can only afford one THIN coat on these Vibes.    yes, apparently the price of the vibe didn't include another coat of paint or better hardener in the clear.
				Posted: Fri Oct 03, 2003 10:41 pm
				by slickshoes
				ye, i noticed the thin coat of paint on my car when i saw this chip on it *!!!!!!!* that wasnt my fault cuz i just spotted it out after i got it home from the dealer********s* has anyone done anything to the exterior of their car like change its color or add more coats or something?
