New vibe owner and member here
Posted: Sat Apr 25, 2015 7:55 am
by southernguy10
Hello all, thanks for letting me join. Just got my 03 vibe auto base model a few weeks ago. It has 182,000 miles on it and has been well maintained. Interior looks like it's never been ridden in. It has the roof rack delete. It's been lowered two inches the right way, no cut springs or anything. Ride quality is better than my vw jetta I just got rid of. I'm loving the car. The only thing I've found it needs so far is a drivers side front axle. I'm thinking of adding the factory body kit to it. Any advice or things I need to watch for or be aware of since this is my first one? Thanks in advance. I'll post some pics
Re: New vibe owner and member here
Posted: Sun Apr 26, 2015 5:50 am
by vibrologist
Welcome Southernguy10!
Sharp looking Vibe! I think I saw it on CL.
Just make sure you have the proper fluids.
This one may have been included in a recall for the ECU. Have a GM dealer check it for you. (Was it included and if so was it done?)
Posted: Sun Apr 26, 2015 8:19 am
by southernguy10
Thanks! You probably did see it on Craigslist. I wound up getting it off the guy for $2600. He had gotten a new vehicle and this was just sitting so he wanted it out of his yard. I think I did pretty good on it. I'm not sure on the ecu recall if it's been done or not. I saw on another post about the window regulator screws recall and mine is doing the popping noise when rolling down they described, so I'll probably take it to the dealership and let them check it for recalls and do what it needs. Are there rrecommended/preferred brands and types of fluids? Besides the obvious 5/30 oil and specific transmission fluid. Also the door catches, is there a fix for them or just replace them when they don't work right? Thanks for any help
Posted: Sun Apr 26, 2015 11:41 am
by trb
Welcome! Car looks pretty good and it sounds like you got a good deal on it.
Good luck with it!
Posted: Sun Apr 26, 2015 4:32 pm
by vibrologist
southernguy10 wrote:Thanks! You probably did see it on Craigslist. I wound up getting it off the guy for $2600. He had gotten a new vehicle and this was just sitting so he wanted it out of his yard. I think I did pretty good on it. I'm not sure on the ecu recall if it's been done or not. I saw on another post about the window regulator screws recall and mine is doing the popping noise when rolling down they described, so I'll probably take it to the dealership and let them check it for recalls and do what it needs. Are there rrecommended/preferred brands and types of fluids? Besides the obvious 5/30 oil and specific transmission fluid. Also the door catches, is there a fix for them or just replace them when they don't work right? Thanks for any help
The tranny fluid is Toyota ATF Type T-IV. AWD has a transmission filter, FWD has only a screen. Still I will drop the pan to clean the magnets.
Engine coolant: I will use the Toyota super long life engine coolant. I understand you can buy a concentrate and dilute it with distilled water.
look what this guy did:
viewtopic.php?f=11&t=43441&hilit=take+out+interior
Posted: Sun Apr 26, 2015 5:22 pm
by southernguy10
Ok great, thanks for the info. Any recommendations on oil? Full synthetic yes, no? Was thinking of using Mobil 1.
Posted: Sun Apr 26, 2015 5:56 pm
by vibrologist
southernguy10 wrote:Ok great, thanks for the info. Any recommendations on oil? Full synthetic yes, no? Was thinking of using Mobil 1.
Well,since you asked, here is the long answer:
http://www.bobistheoilguy.com/motor-oil-101/
Posted: Mon Apr 27, 2015 5:04 am
by cptnsolo77
Looks great ! Lovin the roof rack caps. Been wanting to get them for my Vibe, but after all these years they are still too darn expensive
Posted: Mon Apr 27, 2015 5:18 am
by southernguy10
Thanks. I was fortunate the expensive stuff was done when I got it lol. Ran a Carfax on it and there's no records of wrecks or anything and I'm the third owner. Was originally an Ohio car and wound up here in Tennessee. The guy I bought it from did all the work to it. I think all I'm gonna do is possibly add the factory body kit. But that's a maybe somewhere down the road. I love the car and the looks as is.
Posted: Mon Apr 27, 2015 8:00 am
by Salsa Guy
Welcome to GV! No recall on the ECU for the 03-04 Fwd 1zz. IM gasket it a popular repair. Solid cars should last you many years!
Posted: Mon Apr 27, 2015 9:37 am
by vibenvy
Welcome to GenVibe! Props on posting pictures of your "new" Vibe right away
! It looks like it has been very well taken care of which is always great to see. It's cool that it also has a few mods done to it already. The GM ground effects would look great on it, but good luck getting a hold of them. From what I've read on here, they're very hard to come by these days.
Posted: Mon Apr 27, 2015 11:10 am
by 1gnvibe
Looks sharp! That drop looks a lot like Tein S Tech springs. I put mine on about 6 weeks ago and have been loving it ever since. I'd say it rides even better than stock. Welcome to the Vibe Tribe.
Posted: Sun May 03, 2015 10:19 am
Welcome to GenVibe. Sharp looking first gen.
Posted: Sun May 03, 2015 12:29 pm
by southernguy10
1gnvibe wrote:Looks sharp! That drop looks a lot like Tein S Tech springs. I put mine on about 6 weeks ago and have been loving it ever since. I'd say it rides even better than stock. Welcome to the Vibe Tribe.
Thanks. The springs on mine are bright green I noticed when I put it up on the rack at my brothers shop. Are the Tein springs green or do I have something else on there?
Posted: Mon May 04, 2015 2:03 pm
by Nasmfell
Hi southernguy10, Welcome.
Posted: Wed May 06, 2015 1:43 pm
by vibenvy
southernguy10 wrote: The springs on mine are bright green I noticed when I put it up on the rack at my brothers shop. Are the Tein springs green or do I have something else on there?
I do believe Tein springs are indeed green.
