				Sunroof noise when shut
				Posted: Sat Apr 18, 2015 4:45 pm
				by CHSurvivor
				Ok I first checked the search....no luck
The sunroof panel slider rattles like a (removed) when its closed. I wedge in a pack of gum to stop it chaddering as I drive. Eventually it falls out and starts making noise again. Its dead quiet when the sunroof is open. If I leave the slider open it still rattles. Its coming from the pop up wind deflector inbetween the sunroof and slider....this is slowly driving me insane...
HELP !
				Re: Sunroof noise when shut
				Posted: Tue Apr 21, 2015 4:42 pm
				by CHSurvivor
				no one has a rattle from the sunroof when closed?
				Posted: Thu Apr 23, 2015 4:48 am
				by GOF
				Sorry. I am not well versed in sunroofs. I would look at the linkages that operate the deflector. If you can't find anything loose perhaps a small piece of stick on weatherstrip placed strategically so that the deflector rests against it?
				Posted: Thu Apr 23, 2015 3:40 pm
				by CHSurvivor
				ll giver ago. ! thanks mate
				Posted: Wed Apr 29, 2015 3:06 am
				by CHSurvivor
				no luck rattles when inside slider shut or open. Its the air vent guard that rattles. Its lubricated well. It rattles on the sunroof.....only hwne sunroof is open its quiet
 driving me nucking futs
				Posted: Wed Apr 29, 2015 4:56 am
				by vibrologist
				I don't have experience with this but I have empathy.
Try this: there are 4 screws that hold the glass in place. Open them and push the glass up, or down and tighten them again. Hopefully you find an adjustment that prevents the rattling.
				Posted: Mon May 04, 2015 4:20 am
				by CHSurvivor
				I bought some house door foam about 1/4" thick and placed it under the flap or wind guard that pops up when the roof i open.
I am 99% sure that will fix it....for anyone else in same problem....try that.
Just need to find a bumpy road....
thanks for all the tips
				Posted: Mon May 04, 2015 4:49 am
				by vibrologist
				I looked at my sunroof and noticed there are springs on either side to hold the spoiler up. If these springs are broken or detached they will make the spoiler rattle.
Also if there is friction or wear in the pivots of that spoiler it could cause rattles.
Anyway, I hope the foam trick will do it for you.
				Posted: Tue May 05, 2015 2:56 am
				by CHSurvivor
				no luck, the springs are in tact, sunroof is tight and secure....now it rattles open....this is driving me nucking futs! lol
				Posted: Tue May 05, 2015 6:16 am
				by vibrologist
				Can you replicate the exact sound by knocking various parts of the sunroof?
				Posted: Fri May 08, 2015 10:30 am
				by CHSurvivor
				yes i can, its the wind flap that pops up....it rattles when roof closed...I have put foam on each side of it.
				Posted: Fri May 08, 2015 11:33 am
				by vibrologist
				I don't have the problem so I don't have to do this. Non the less I tell you what my approach would be: I would take it apart. I would inspect every piece, clean it, lube it where it was lubed from factory and put it back together. There is no guaranty that this will fix it, but I have fixed a few untraceables in that manner.
