body difference between 2wd and 4wd
Posted: Wed Mar 18, 2015 2:45 pm
Hello
I just bought a 2004 2wd vibe. I have to change the rear axle beam since it bent from an impact.
I found a local junkyard that sells the beam for 60$. The thing is they just post a picture of the car on facebook. If you call them they dont really know the cars specs.
Is the any way to tell if its a 2wd or 4wd from the picture ?
Can i take one from a 2wd matrix ? I know they are the same car. But sometimes there are slight differences between the 2 models.
Anything else i should know ? (Abs or something that will not fit if not same option...).
Thanks
Thanks
