what is a good throttle body spacer for 09 gt?
Posted: Wed Mar 18, 2015 9:29 am
by spartans21
Re: what is a good throttle body spacer for 09 gt?
Posted: Wed Mar 18, 2015 10:19 am
by TraumaForYou
As far as I know and have seen/heard, they don't do anything at all. They are a waste of time and money. :geek:
Posted: Wed Mar 18, 2015 10:28 am
by spartans21
Thanks man. I am just looking for things to do to my car with a few extra bucks I have.
I also wanted to know if there are any exhaust tips out there for same GT that would increase the pitch?
Posted: Wed Mar 18, 2015 1:38 pm
by TraumaForYou
spartans21 wrote:Thanks man. I am just looking for things to do to my car with a few extra bucks I have.
I'm sure there are, you can probably look around online and find some good ones. I believe I have seen some threads about it too.
Posted: Sat Mar 21, 2015 11:54 am
by vibenvy
A muffler tip will not change the sound of the exhaust. To change the sound of the exhaust you need to add an aftermarket muffler and / or bigger exhaust piping and / or an aftermarket catalytic converter and / or a header.
FYI, Magnaflow makes a direct fit catback exhaust system for 2009-2010 Vibe GTs. I have it on my 2009 Vibe GT and am very happy with it. It has a nice sound without being overly buzzy or droning.
Posted: Sat Mar 28, 2015 4:50 pm
by spartans21
Thanks for the reply. I was looking at the Magnaflow Cat-Back Exhaust, I don't plan on swapping the cat converter but I did want to upgrade the exhaust header. I need to locate a header though, I only see them for the 1.8 L :/
Posted: Sun Mar 29, 2015 6:12 am
by lannvouivre
spartans21 wrote:Thanks for the reply. I was looking at the Magnaflow Cat-Back Exhaust, I don't plan on swapping the cat converter but I did want to upgrade the exhaust header. I need to locate a header though, I only see them for the 1.8 L :/
Pull the heat shield off of your exhaust manifold and look at the design. It may already be a header. You have to be careful about changing the diameter of the runners as well, you do actually need them to be a size appropriate for how much flow the engine produces or the exhaust gas will cool and slow down.
