LIFTING 2005 VIBE!!! NOT BIGGER TIRES...
Posted: Mon Feb 09, 2015 5:36 pm
by mango02
Could not find anything on lifting VIBE. Just want to raise it 1" or 2" DO NOT want BIGGER TIRES. Would like to raise suspension. Springs? Bushings? Blocks? All I see is LOWERING need to go up because of rough roads.
Re: LIFTING 2005 VIBE!!! NOT BIGGER TIRES...
Posted: Mon Feb 09, 2015 7:33 pm
by gtv237
There's not really a simple way to increase height or travel without ruining the suspension geometry.
Posted: Tue Feb 10, 2015 11:58 am
by mango02
When you lower a VIBE you screw up the GEOMETRY. When you install different aspect ratio tires or size you screw up the GEOMETRY. Has anyone experimented and raised a VIBE? There is one RALLY VIBE did he use stock springs? does anyone make anything for a VIBE to make it TOUGHER, STRONGER? Does Toyota TRD make anything for a MATRIX Corolla? Skid Pan like VW makes for the JETTA?
Posted: Tue Feb 10, 2015 7:52 pm
by Derf
Link to a thread on the Vibe:
viewtopic.php?f=30&t=40933&p=482114&hil ... ft#p482114" onclick="window.open(this.href);return false;
Which ultimately leads to a link on a Matrix with the same suspension.
http://matrixowners.com/index.php?/topi ... trix-lift/" onclick="window.open(this.href);return false;
I have not seen an actual skid plate, but this is at least metal.
http://www.kamispeed.com/BEATRUSH-Alumi ... 516010.htm" onclick="window.open(this.href);return false;
Posted: Thu Feb 12, 2015 12:22 pm
by mango02
DERF thanks! skid pan looks good for me. The lift looks good but unable to go that route. No PLASMA cutter and no TIG welder. Thanks for the THREAD!!! DERF.....
Posted: Thu Feb 12, 2015 3:50 pm
by lannvouivre
mango02 wrote:When you lower a VIBE you screw up the GEOMETRY. When you install different aspect ratio tires or size you screw up the GEOMETRY. Has anyone experimented and raised a VIBE? There is one RALLY VIBE did he use stock springs? does anyone make anything for a VIBE to make it TOUGHER, STRONGER? Does Toyota TRD make anything for a MATRIX Corolla? Skid Pan like VW makes for the JETTA?
He is on stock suspension with a skidplate in front.
Posted: Fri Mar 06, 2015 6:39 am
by Doug14
Almost $300 for that skidplate!? holy cow!
Posted: Mon Mar 09, 2015 8:02 am
by KITT222
The rally Vibe has AWD front springs (AWDs are slightly raised) and 09 rears, though the spring rate in the rear may be a bit much for the lighter car. The skidplate is a custom plate of really thick metal. Next time I'm there I can inquire.
