Melted (not blown) alternator 100A fuse
Posted: Sun Feb 01, 2015 3:09 pm
by Thunderscreech
I've got a weird one with a theory is like to run by y'all. I've had to replace my 100 amp alternator fusible link a couple times burnout because the filament burned out; the whole thing got HOT and the plastic socket it mounts to melted and charred!
I cleaned out the plastic, cleaned the bolts they link to, then replaced it after auditing for shorts. Everything was fine for a year then it happened again. The filament is fine but the prong for the link on the engibe side got reall hot and melted just that side.
My theory: I may have a bad wire or connection on that side and the resistance is turning that post into a heating element.
How crazy does that sound? Or should I be considering other causes?
Re: Melted (not blown) alternator 100A fuse
Posted: Sun Feb 01, 2015 7:28 pm
by vibrologist
I don't think that is crazy at all. Some mechanics use infrared thermometers to locate shorts.
Posted: Mon Feb 02, 2015 5:54 am
by beemerphile1
A poor connection causes arcing,
arcing causes heat,
heat melts things.
You need to replace both sides of the connection.
