09 tuneup, now has horrible gas mileage
Posted: Tue Jan 20, 2015 4:35 pm
by chearn4522
we just did a tuneup on our 09 vibe 1.8L engine, changed spark plugs..( only 2 of the old ones were hand tight ) new serpitine belt, cleaned K&N filter and changed the oil...now getting horrible gas mileage...13 to 16 miles per gallon...HELP
Re: 09 tuneup, now has horrible gas mileage
Posted: Tue Jan 20, 2015 6:12 pm
by Mark
I would start by pulling the new plugs and verifying that they're the right ones, and make sure they all look like they're firing. Then make sure the coil packs are fully seated on the plugs. I guess I'd double check the belt routing and that I got the right belt. I've had parts stores give me the wrong one more than once. Throw away the KN filter and pick up a NAPA Gold or other other good quality filter. If everything checks out try disconnecting the negative battery terminal for 20-30 minutes to reset the computer.
I'd change the air filter and clean the MAF too, unless that's been done recently.
Posted: Tue Jan 20, 2015 6:13 pm
by Caretaker
As a Corolla Vibe owner myself, I can only offer a suggestion of the obvious:
Did you order the $9 Denso iridium plugs from Rock Auto, or did you put in some two pronged E3 plugs that belong in lawn mowers? If you did not put in the NGK or preferably the Denso plugs, please do so and report back. I'm hoping that is all there is to this. Good luck.
Posted: Wed Jan 21, 2015 9:14 am
by Salsa Guy
Yep Check plugs first then air filter
Posted: Wed Jan 21, 2015 9:42 am
by triz
Would not be a bad idea to unhook the battery for a few minutes and let the computer relearn.
Posted: Wed Jan 21, 2015 12:00 pm
by Mark
Forgot to mention another obvious culprit: tire pressure. With the stock 205/55 tires on mine it's really almost impossible to spot a tire that's down to 20psi just by looking. But boy can that suck the mileage down.
Posted: Thu Jan 22, 2015 6:07 am
by ParknVibe
Mark wrote:Forgot to mention another obvious culprit: tire pressure. With the stock 205/55 tires on mine it's really almost impossible to spot a tire that's down to 20psi just by looking. But boy can that suck the mileage down.
Yes,... always check your tire pressure!!! ...at least once a month,
Posted: Thu Jan 22, 2015 6:13 am
by cptnsolo77
Possible the K&N was over oiled ?
Posted: Thu Jan 22, 2015 8:00 am
by tpar1220
cptnsolo77 wrote:Possible the K&N was over oiled ?
i was thinking this very thing. on my dirt bike, if i over oil the filter it will foul plugs left n right!
Posted: Thu Jan 22, 2015 11:53 am
by chearn4522
re-checked the plugs...denso iridium, coil pacs look good, changing out the K&N for Napa Gold today, have the oil re-checked today also as well as tires rotated..will get back with y'll .....ty for all the help...
Posted: Fri Jan 23, 2015 4:51 am
by cptnsolo77
You may have to clean the MAF sensor if it was over-oiled.
Posted: Fri Jan 23, 2015 6:31 am
by vibrologist
Use paper towels to blot off any extra oil on the K&N.
Posted: Sat Jan 24, 2015 7:31 am
by triz
Did you reset the computer to allow it to relearn?
