How do you remove the front door scuff plate?
Posted: Sat Dec 20, 2014 6:01 pm
How do you remove the front door scuff plate(located right beside door sill)that holds down the floor carpet? I need to remove it on the passenger side to access the wiring harness for replacement of the oxygen sensor. My Vibe is AWD and according to service manual harness disconnect is located quite close to scuff plate under carpet unlike the FWD which is located close to the center console. If anyone has pictures or a link to a video showing how to remove this part, it would be greatly appreciated.
