P0138 fault code
Posted: Thu Dec 18, 2014 12:10 pm
I have a 2005 Pontiac Vibe AWD with 302,000 KM on it. It is starting to throw P0138 fault codes. From the research that I have done on the Internet, it looks like this is the oxygen sensor on the catalytic converter. Is this correct? If so, it looks like the wiring harness disconnect is under the carpet on the front passenger floor. How do you access the connector? Do you have to remove the door sill trim panel first or can you remove push in clips by center console and roll carpet back? Do you need a special tool to remove the sensor? If somebody has done this and could comment or provide links with pictures, it would be greatly appreciated. Also part number and where you bought it would be nice as well. Thanks.
