DRL disable attempt
Posted: Wed Dec 17, 2014 9:09 am
Ok, looked through some of the threads on disabling the Daytime Running Lights and having the fogs come on with park lights and highbeams. I went with the method for drl disable by taking out the black relay box under dash and cutting pin 6 and splicing to pin 14. I also cut the green wire under steering column and spliced the green wire next to it method for the fogs.
I tested it out in my garage with the ignition in run position but not with the car running. That was a week ago, and it all worked as supposed to. I just noticed today in reflection if truck in front of me that my drl's are off like they're supposed to. It's real cloudy today so I thought I'd turn on the parking lights with the fogs. When I flupped the light switch to marker lights the actual headlights come on. Checked it again later with car not running and still works like supposed to, but doesn't work correctly with car running. Any ideas?? Sorry for long story.
