Sway Bar Links replacement
Posted: Thu Nov 06, 2014 8:11 am
by Vibelo
I have to replace both from sway bar links in the front of my 2004 Vibe FWD Vibe 138,000 miles. Has anyone done this? Any tips/instructions?
Re: Sway Bar Links replacement
Posted: Thu Nov 06, 2014 8:24 am
by sideshowalan
It's pretty straightforward once you have the wheels up.
Only 2 tips I can offer are:
-- Release the tension on the link with a floorjack under the knuckle
-- Make sure you have a proper fitting socket beforehand to hold the link stud in place when you remove the bolts.
Don't know the size or whether it's a torx/hex socket. Without this the stud will just spin in place.
Posted: Thu Nov 06, 2014 11:10 am
by Vibelo
Thanks a bunch! That helps!
Posted: Thu Nov 06, 2014 7:49 pm
by lannvouivre
You need an allen wrench or something else with a hex head.
