My CV joint came apart when I was removing the trans
Posted: Sat Oct 25, 2014 3:24 pm
by trb
so I'm assuming I can just add some grease and put it back together? I couldn't get the end out of the trans while it was in the car, but eventually got the trans out.
Thanks!
Re: My CV joint came apart when I was removing the trans
Posted: Sat Oct 25, 2014 5:09 pm
by gtv237
As long as the boot didn't tear you can just put it back together. You will need to tighten the band once you're all done.
Posted: Sat Oct 25, 2014 7:17 pm
by trb
Thanks. I kinda thought so, since it came apart so easily. The boot looks fine so I should be good.
