Looking for a headlight bolt
Posted: Sun Oct 19, 2014 8:21 pm
Hey folks, still enjoying the 2005 Vibe GT as a daily foul weather driver (getting ready to put the winter tires on, it's presently 35 degrees outside):
but I'm still trying to make it a bit nicer. I'm missing one of the 2 bolts that holds my passenger side headlight housing down and as a result it wobbles a bit.
It's the bolt that is basically where the 8 arrow is pointing in this GM parts diagram, but they are referring to the whole assembly and do not specify a number for the actual bolt anywhere that I can see.
There is a screw, 2 in the diagram, part number 88971488 but that is a different screw as best I can tell. Looking up the Toyota Matrix equivalent, it appears that it might be this bolt 3 they have called "Lens & housing bolt" - which is different from the lower bolt and is not contained in the GM diagram:
However that is still not clear and if possible I'd like to order the part from GM as I am already ordering some bigger GM parts for my other car anyway and would rather not pay $5 to ship a $0.75 bolt.
Does anyone have a clue what the GM part number might be? Thanks
