slight misfire at idle
Posted: Tue Oct 07, 2014 6:44 am
by cmpltvertigo
Hey folks my car, 2003 Vibe Base Model, recently started doing what I can best describe as a slight misfire (vibration). It is noticeable when that car is at idle such as at a stop light. I bought the car 2 years ago and have put about 12K miles on it (currently at 123K), so far the only maintenance I have done is replaced the air filter, intake gasket, and scheduled oil changes. Does anyone have any suggestions as to what it can be?
Re: slight misfire at idle
Posted: Tue Oct 07, 2014 7:50 pm
by Chiadog
Fresh plugs wouldn't hurt, but if it is missing I think it would throw a code? Check the serpentine belt and tensioner. With a cold engine you can run the car for a minute with the serpentine belt removed to see if the "misfire" disappears. Next try cleaning the mass air flow sensor, I think it is just two little wires that are pretty well hidden. Search for threads here. Try to do things one at a time to nail down the actual problem.
Posted: Thu Oct 09, 2014 7:40 pm
by lannvouivre
inline-4-cylinder engines naturally have balance issues that cause vibrations at certain engine speeds that increase with normal wear and tear. Newer Toyota engines, such as the 2AR-FE, have got a balance-wheel meshed to the crankshaft to keep the idle smooth as the car ages.
Posted: Wed Oct 15, 2014 6:48 am
by cmpltvertigo
First of all thanks for all the comments so far
Update: It looks like I may have been the victim of bad gas. The symptoms started with my last tank fill-up; I have since gone through that gas and filled up at my usual location and the symptoms have decreased by 90%.
