Coolant flush
Posted: Sun Sep 28, 2014 1:52 pm
by dnoishere
...so I did a flush and fill today but I barely used a gallon of the premix....manual says approx. 6.9 qts. is capacity....what gives? Yes I got air out...drained the block too...
Re: Coolant flush
Posted: Mon Sep 29, 2014 6:38 am
by triz
Just monitor it regularly for now if your sure you got all the air pockets out. Maybe try raising the car in the front a bit.
Re: Coolant flush
Posted: Mon Sep 29, 2014 10:10 am
by Chiadog
Not sure this applies to the Vibe, but the heater setting should be on "hot" when draining coolant to help get it all out of the block. Also, when doing a drain/refill for the first time on a car I haven't done before I always measure what comes out and compare that to what goes back in! And as Triz says, watch it closely for a while.
Re: Coolant flush
Posted: Mon Sep 29, 2014 1:30 pm
by dnoishere
...yeah okay...had to add a little to it today. Did have heater on too...will keep eye on it.
