Always On Cigarette Lighter Socket
Posted: Sat Sep 20, 2014 4:15 pm
by danlee
2009 Pontiac Vibe 2wd 2.4L
I want to make my Cigarette Lighter outlet 'Always On', so I can use it to charge my USB devices with an USB adapter. I have several questions.
1. How do I remove the outlet from the console to get to the wires? I removed the radio & shifter bezels, but can't get the bezel off that holds the AC & Lighter outlets.
2. I would opt to install a jumper in the fuse panel connection to connect a hot 12 Volts to the wire that feeds the Lighter outlet, but I removed all of the fuses, one at a time, and the power(key on) never went off the lighter. There is a 15 Amp fuse in the location marked Inverter & lighter, but removing that fuse did not disable the lighter. Where is the fuse that feeds the lighter?
Re: Always On Cigarette Lighter Socket
Posted: Sun Sep 21, 2014 9:58 am
by vibrologist
Answer to 1: pull the dial off the fan switch, remove the hidden screw.
Question 2, I don't know.
Posted: Mon Sep 22, 2014 7:26 pm
by KITT222
1) Not really sure on the second gens...
2) Double check to see if there's a fuse in both the underhood and under-dash fuse box.
Posted: Tue Sep 23, 2014 4:20 am
by beemerphile1
I left the original receptacle as is because it powers my dash cam and triggers it to come on when the receptacle receives power.
I added a triple receptacle splitter together with a USB receptacle in the cubby under the radio.
I got it off the shelf at Walmart and it is nearly a perfect fit. I did cut out the back of the cubby.
http://www.walmart.com/ip/INSTEN-Three- ... k/28884661
I cut the plug from the cord and hardwired it to an always on source. I don't remember what source I used but be sure you have an adequate source for powering multiple devices.
Posted: Tue Dec 02, 2014 2:05 pm
by AZSage
Here is detailed description on how to remove heater bezel cigarette lighter and inverter (see PDF attached)
Pontiac Vibe Bezel 1.pdf
Removal of Vibe AC heater bezel
(423.61 KiB) Downloaded 339 times
