front wheel bearings longivity=-????=-
Posted: Fri Sep 19, 2014 11:40 am
by jamesmetairie
on average how many miles do you guys figure a 2005 Vibe gets outta original front wheel bearings ?
Re: front wheel bearings longivity=-????=-
Posted: Fri Sep 19, 2014 12:13 pm
by Raven
Our '06 has 260,000 km or 160,000 miles and we only replaced the right front around 100,000 miles. The left is still going strong.
Posted: Fri Sep 19, 2014 3:17 pm
by jamesmetairie
our 04 corolla needed both rear around 90,000 miles.
Posted: Sun Sep 28, 2014 4:01 pm
by bluneon
do you live/drive on a dirt road often? if yes, wheel bearing life expectancy is reduced.
do you drive on crappy pot hole ridden roads? if yes, wheel bearing life expectancy is reduced.
do you drive in water deep enough to submerge the wheel bearings? if yes, wheel bearing life expectancy is reduced.
do you drive on completely smooth, clean roads? if yes, wheel bearing life expectancy is infinite.
there are no definitive answers on how long or how many miles wheel bearings last.
Posted: Mon Oct 20, 2014 7:36 am
by ehoff121
Anyone have thoughts on the best brand for replacements?
Timken?
Posted: Mon Oct 20, 2014 12:15 pm
by KITT222
Bearings are a pain because, even if you're a DIY'er, not everyone has a press, and the front bearings need to be pressed in and out. My front left went somewhere around 100k. Others seem good. I'd ALWAYS get the more expensive bearing of the choices. At Advance we sold National bearings, and they're a good brand. Even come with a two year warranty. But like said above, conditions will make or break a car.
Posted: Thu Feb 12, 2015 3:55 pm
by Mojo72
I'm over 158,000 miles and have noticed a "whirring" noise from the direction of the RF wheel over the past few days while driving the freeway. Based upon past experience with my PITA 2002 Ford Explorer, I'm thinking its the wheel bearing. Does anyone have an idea of how much longer I can realistically drive it and how much I can expect to pay (dealer and or non-dealer) for a replacement?
Posted: Thu Feb 12, 2015 4:47 pm
by vibrologist
Mojo, I don't know the cost, but you can ask the dealer service and your trusty neighborhood mechanic for an estimate.
It appears a repair is needed. Why would you postpone it? Do you like the whirring noise?
Posted: Fri Feb 13, 2015 5:32 am
by sideshowalan
Wheel bearings are essential to safe operation of your car. The longer you wait, the worse they'll get. When wheel bearings completely fail, the wheel will either flop around in the fender or completely separate from the car. Get it fixed asap. The longest I've driven around on bad wheel bearings is 2-3 weeks.
Posted: Fri Feb 13, 2015 7:02 am
by Mojo72
Thanks for the quick feedback and estimates. It's never easy to squeeze a repair into an already busy schedule, but sometime next week works.
Have a great weekend!
Posted: Tue Apr 21, 2015 8:22 am
by clownshoes
I've replaced 2 so far. 1 front and 1 rear with AC Delco I believe. Now I have another one out. 241K on the clock, highway driving only.
Posted: Thu May 07, 2015 7:27 am
by PonchoGT
Improperly aligned or tire(s) with an already cupped tread pattern can also simulate that maddening "whoo-whoo" noise bad wheels bearings emit. I bought my Vibe used thinking it had a bad rear wheel bearing, only to discover one of the rear tires was cupped from misuse by the previous owner.
