205 60 16 blizzak snow tires fit ?
Posted: Thu Sep 18, 2014 6:21 pm
by markd78
Have a 2009 2.4 with 17's, found camry 16 114.3 steelies with hubcaps, looking at almost new set of blizzaks 205 60 16, wondering about height ? I know your supposed to stay within the 3% rule on tires, any problems with the fit ??
Mark
Re: 205 60 16 blizzak snow tires fit ?
Posted: Tue Sep 23, 2014 2:51 pm
by dragon64
There shouldn't be any problem. You will just have to remember that the speedo will be off.
Posted: Tue Sep 23, 2014 5:05 pm
by KITT222
You should be just fine. If anything you'll get a tiny boost in height.
Posted: Tue Sep 23, 2014 7:29 pm
by vibrologist
Those tires will fit on the rims, but I don't know if the rims fit on the Vibe. I thought we need 5x100,
Posted: Tue Sep 23, 2014 9:01 pm
by KITT222
vibrologist wrote:Those tires will fit on the rims, but I don't know if the rims fit on the Vibe. I thought we need 5x100,
The second gen 2.4s are different. They have a different bolt pattern (5x114.3). But all 1.8 Vibes have the 5x100 pattern.
Posted: Wed Sep 24, 2014 3:56 am
by vibrologist
Thanks for the clarification!
Posted: Sat Sep 27, 2014 5:57 pm
by vibenvy
The stock 16" tire size for 2009-2010 Vibes is 205/55/16, so a 205/60/16 should be fine.
KITT222 wrote:The second gen 2.4s are different. They have a different bolt pattern (5x114.3). But all 1.8 Vibes have the 5x100 pattern.
Yep...
All 2003-2008 Vibes = 5x100
2009-2010 Vibe 1.8L Base = 5x100
2009-2010 Vibe 2.4L Base / AWD / GT = 5x114.3
