				Another "Will They Fit" Thread - Sebring Rims
				Posted: Thu Sep 04, 2014 4:57 am
				by CanadianJ
				Help save me from steelie Hell.
These 16" Sebring rims are 5 x 100 so will fit the bolt pattern on my 09 base.
Does anyone know if they will fit otherwise? EG - offset and clear the calipers.
The seller isn't sure on the year/model they came from. Thanks!
				Re: Another "Will They Fit" Thread - Sebring Rims
				Posted: Thu Sep 04, 2014 3:16 pm
				by Chiadog
				Not sure, but this may help. I'm running 2000 (I think) 15" Chrysler Cirrus steelies on my 2005 base Vibe.  The Chrysler center hole is larger than the 05 base Vibe, so hub centric rings should be used. 56.1mm - 54.1mm, I think. I haven't put the rings on mine yet, seems to drive fine without them. I plan to put the rings on this Fall when I change tires.
				Posted: Thu Sep 04, 2014 5:07 pm
				by vibrologist
				I bought a set of 15" aftermarket alloys. Before I paid I put one on the front axle to check the fit. Everything was good.
				Posted: Fri Sep 05, 2014 7:08 am
				by CanadianJ
				Thanks guys. Everything looks the same from what I can tell online - bolt pattern, similar offset etc.
I have a bit of a drive to get them so was hoping someone had installed these on a Vibe in the past.
