Will they fit
Posted: Tue Sep 02, 2014 5:40 pm
by flyfishn5
Hello all.
Does anyone know if Jetta rims will fit a base vibe?
Cheers,
James.
Re: Will they fit
Posted: Tue Sep 02, 2014 6:09 pm
by lannvouivre
http://www.discountedwheelwarehouse.com ... erence.cfm" onclick="window.open(this.href);return false;
You're looking for 5 bolt 100mm spacing.
Re: Will they fit
Posted: Tue Sep 02, 2014 6:19 pm
by Raven
From what I see...
http://www.roadkillcustoms.com/hot-rods ... z3CDNgrcKr they should be identical up to 2005. Even the center bore is the same 57.1. But what size are they, 15" or 16". Jettas come with either one. If they are 15", you'll have to adjust the tire size to get the same approximate diameter.
http://www.1010tires.com/Tools/Tire-Size-Calculator
Re: Will they fit
Posted: Tue Sep 02, 2014 7:44 pm
by vibrologist
A word of caution: VW rims have high offset. Vibes don't. The VW rims still may fit, but it will affect the steering geometry. If you scroll down on the linked Roadkill VW search you will neither find a Vibe nor a Matrix.
