The axle enigma
Posted: Sun Aug 24, 2014 4:47 pm
by 3cyltom
Just getting around to getting our new (old) 03 vibe going. Finally found a good engine locally and on the test drive I noticed it clicks and shimmys like a bad cv axle. And the driver side axle outer boot is blown. Now for the enigma. Someone before me installed a 6spd trans. It's a base model vibe 2wd with a 1zz engine. Do I order a left hand axle for a base model or a gt model? The gt 6spd axle for the driver side is discontinued at autozone and advance and oreilly. I could order it online, but not sure which one to order. ??
Re: The axle enigma
Posted: Mon Aug 25, 2014 2:35 am
by sideshowalan
Base axle will fit, there are no mods necessary to swap out a 5 speed for a 6.
Re: The axle enigma
Posted: Mon Aug 25, 2014 6:18 pm
by Flip-Side
Simply put, you can use a base or gt axle on the on the driver's side. Only a GT axle will work on the passenger side on a real GT. I am unsure if this is needed on your car since it is technically a base vibe. The XRS/GT cars have a carrier bearing on the passenger axle.
A tip:
If the axle is stuck in the trans and you can't seem to get it free, grab a free slide hammer from an auto parts store, loop a metal coat hanger wire around the back of the axle, attach the wire end to the slide hammer shaft, and then give it a few knocks. Coat hangers have many uses in my garage.
Re: The axle enigma
Posted: Tue Aug 26, 2014 11:34 am
by lannvouivre
Ooo, nice! You got lucky to have the 6 speed!
Re: The axle enigma
Posted: Tue Aug 26, 2014 3:11 pm
by 3cyltom
We have had the vibe for a while now. Just drove it for real Sunday. I've had manual trans cars most of my days, and this is my 1st 6 speed. Gotta say it takes a lot of courage to go for the 6th gear (sposed to be reverse lol). I'll even fess up I clashed the metro this am going for 6th. I'm not sold that the left axle will fix my clunk noise, but the boot split wide open and puked its grease all over everything. And yes the right axle is a solid axle. No carrier bearing. So I think the p/o just replaced gear boxes.
Re: The axle enigma
Posted: Tue Aug 26, 2014 3:17 pm
by 3cyltom
And yes the axles were welded (really stuck) when I pulled the gearbox for my engine install. I used my trusty 3lb hammer and a chisel on the flat of the cv. A few good smacks and they popped right out. An old junk yard trick of mine.
Re: The axle enigma
Posted: Wed Aug 27, 2014 8:06 pm
by 3cyltom
Got my left axle changed. Quite simple to swap. And the base model 5 spd axle works just fine. It fixed several noise issues I'm having, but there still is a mystery clunk when I'm driving. Thinking it's either a loose engine mount or possibly the right axle may be bad also.
Re: The axle enigma
Posted: Thu Aug 28, 2014 9:07 pm
by Flip-Side
The 6 speed is really best suited to the 2zzge engine. The 1zzfe has all the low end torque a 5 speed needs, which the 2zzge lacks. It really is a torque-less wonder, but a banshee at high rpm. You will be perfectly fine though, since you can just skip gears with the better torque the base 1.8L has. Glad to hear the axle swap went well, they really are pretty easy on these cars though the axle nuts usually gives me fits due to the use of dimples instead of cotter-pins.
