another cooling issue
Posted: Mon Aug 04, 2014 4:10 pm
by o2ej
ok, so the kid takes mom for driving practice. a/c on, 10 miles on the highway, then turn into Tacoma for some city driving. long story, short, the car overheats. after it cools, with the a/c off, they return home.
I drive to work this morning, temp stays in the middle as usual. i check the fan status after parking in the driveway. turn a/c on-->no engine cooling fan on. a/c works fine, cold air, etc.
looked at fuse, i think it's ok. going to buy one anyway. is there a relay i need to check as well? want to cover bases
thanks
Re: another cooling issue
Posted: Tue Aug 05, 2014 11:58 am
by Chiadog
From what I see on my 05 Base wiring diagram, there are two relays for the engine cooling/AC fan (fan 1 and fan 2). It may be possible that the fan motor is running, but the fan itself is loose on the shaft of the motor.
Posted: Tue Aug 05, 2014 2:01 pm
by gtv237
And don't forget a bad ECT sensor can keep the fan from coming on as well. Some cars even have a seperate thermal fan switch.
Posted: Tue Aug 05, 2014 2:03 pm
by o2ej
voltmeter test says power to fan motor. turned on a/c and fan tried to spin but just couldn't. i guess its time for a new fan assy.
Posted: Tue Aug 05, 2014 8:54 pm
by lannvouivre
o2ej wrote:voltmeter test says power to fan motor. turned on a/c and fan tried to spin but just couldn't. i guess its time for a new fan assy.
What about the ground?
Posted: Wed Aug 06, 2014 7:44 am
by o2ej
lannvouivre wrote:o2ej wrote:voltmeter test says power to fan motor. turned on a/c and fan tried to spin but just couldn't. i guess its time for a new fan assy.
ground for the fan? I don't have the wiring schematic. I will try to trace it back from the fan connection.
On another note, any ideas for the cost of rebuilding the fan motor? I have found the fan assy. online priced from 70 to 300. the avg. price for a fan motor is around 100$. just wondering if anyone has had a fan motor rebuilt...
