differences between the base vibe and the GT
Posted: Mon Jul 28, 2014 5:13 pm
by WestC4
could someone please help me out with the overall differences between a base vibe and a GT model. I know they have different hp ratings, so I am curious as to just how much different they are from each other. are the differences basically just ecm/pcm tuning, or is it more complicated as in different engine components (internal parts, external parts), gearing, etc? I'm pretty sure that from 03-08 all vibes used a 1.8L engine, and the 2.4 wasn't intro'd until 09, is this correct? if so then an 08 base vibe would have the same engine as a GT model, correct?
I appreciate the help and clarification
thanks
West C4
Re: differences between the base vibe and the GT
Posted: Mon Jul 28, 2014 6:16 pm
by Derf
This should cover most of what you are looking for:
viewtopic.php?f=11&t=40003#p474445" onclick="window.open(this.href);return false;
Several options depend on model year.
Posted: Mon Jul 28, 2014 6:29 pm
by trb
Edit: Thanks Derf, I thought it was Kitt that did the comparison between the two on here, but from what I've read, the GT 1.8L is basically a completely different motor than the base 1.8L. I don't think there are many parts that will interchange between the two. http://en.wikipedia.org/wiki/Toyota_ZZ_engine" onclick="window.open(this.href);return false;
The GT models also have 4 wheel ABS disc brakes and I believe some different suspension items and aluminum wheels standard.
Hope this helps!
Posted: Tue Jul 29, 2014 4:32 pm
by WestC4
Thanks for clearing g things up
