Dark times but I see a light.... '06 Vibe AWD, 160k
Posted: Sun Jul 20, 2014 7:23 am
Been some challenging financial times and have tried to stay current with the upkeep of my Vibe. The upkeep, unfortunately, had outpaced the finances up until very recently. I'm in a decent place now and need to either pour some, I'm thinking, major work into the Vibe or seek out another set of wheels. Aside from the gas mileage being terrible, the car actually runs fine. I'm due for an inspection in the next few weeks and am thinking that I may face some probs with the engine light on and so forth.
I recently went out and bought an Autel MS310 OBDII scanner. After the scan, I see that there are several codes that are flagged. I'm not afraid to get in and work on this vehicle but if it is going to take major equipment, I may not be prepared for that.
The codes flagged are as follows:
P0171 - System too lean bank 1
P0031 - HO2S heater control circuit low bank 1 sensor 1
P0037 - Same as above but sensor 2
P0134 - O2 sensor circuit No activity detected bank 1 sensor 1
Then, I also received the following two codes included just after the above four codes but they happened to be duplicates of the same codes above but with "Pd" noted on the scanner screen:
P0031 - same as above but with "Pd"
P0037 - same as above but with "Pd"
Any advice is so greatly appreciated. If possible, please don't be afraid to be overly specific as I am a newbie at this for the most part
