2009 Matrix clock transplant
Posted: Mon Jul 14, 2014 5:56 am
I'm thinking of swapping the HVAC control assembly from a Matrix into my Vibe, because the Matrix has a clock in place of the tiny cubby. It looks like a direct fit except for the clock connector.
The connector has 4 pins. Apparently the pins are:
Dome fuse
ACC fuse
Panel fuse
Ground
It seems that all three of these power sources are switched, right? How would the clock maintain the time? Maybe the Dome is always powered, which explains why you can turn interior lights on even if the car is off. So I suppose Panel would be for illumination and ACC would be for turning the face on and off. Assuming this is the case, I can tap off the radio yellow wire for Dome, red wire for Acc, and orange wire for Panel.
Has anyone done this?
Dome fuse
ACC fuse
Panel fuse
Ground
