Exedy KTY-14 clutch kit for 03 GT?
Posted: Mon Jun 16, 2014 6:21 pm
by ken99287
Is the exedy kty14 the correct clutch for the gt? There seems to be contradicting information on the interweb.
Resurface the flywheel or get a new one? Any suggestions on a new flywheel?
Thanks in advance!
Re: Exedy KTY-14 clutch kit for 03 GT?
Posted: Tue Jun 17, 2014 4:14 am
by gtv237
I would get a Sachs brand clutch off rockauto.com. Sachs is the company GM uses for all their clutches.
Posted: Tue Jun 17, 2014 4:18 am
by hotbug1776
gtv237 wrote:I would get a Sachs brand clutch off rockauto.com. Sachs is the company GM uses for all their clutches.
I believe Exedy is the clutch Toyota uses for their cars...
Posted: Tue Jun 17, 2014 4:31 am
by ken99287
Yeah, I'm going to get the Exedy because that's stock, but I was asking if the KTY14 is the correct kit for the GT. Some sites say yes, some say no.
The Vibe uses a Toyota drive train, I should probably stick with Toyota recommend parts.
Posted: Tue Jun 17, 2014 5:04 am
by gtv237
ken99287 wrote:if the KTY14 is the correct kit for the GT.
That I don't know. As far as clutches go anything from an OEM will be a step up from an aftermarket replacement part.
Resurfacing a flywheel is perfectly fine. The only problem is now days it's almost cheaper just to replace it. I got a quote for $45+ tax to resurface mine and RockAuto's selling Sachs flywheels for $60.
Posted: Tue Jun 17, 2014 6:48 am
by ken99287
If that's all it costs, I'm getting a new one. They say a flywheel can only be cut twice before you start to get issues with clearances or something (too thin).
Posted: Tue Jun 17, 2014 7:17 am
by gtv237
ken99287 wrote:If that's all it costs, I'm getting a new one. They say a flywheel can only be cut twice before you start to get issues with clearances or something (too thin).
You can use flywheel shims to make up for that but you've got to think, why does a flywheel need to be resurfaced? Generally it's because it's either warped or misshapen. As you cut material off, you make it thinner. The thinner it is the quicker it heats up and the quicker it will warp or misshape. IMO it's just better to just replace it.
Of course if your flywheel has never been resurfaced before and looks pretty good, its perfectly fine to resurface it. As long as the price is right.
Posted: Tue Jun 17, 2014 7:46 am
by ken99287
Rock auto has my flywheel for $58, but shipping is about $20!
Napa will cut mine for $30 and only 1 hour turnaround time.
Posted: Tue Jun 17, 2014 8:03 am
by gtv237
ken99287 wrote:Rock auto has my flywheel for $58, but shipping is about $20!
Sounds like resurfacing might be the best value to you. Just look your flywheel over good. If its visibly warped, grooved or misshapen, I would just replace it.
Posted: Tue Jun 17, 2014 8:09 am
by ken99287
Yeah, I'll get a new one if it's damaged. If I just need it scuffed up to get the new clutch seated right/broken in, that's fine.
Posted: Tue Jun 17, 2014 8:10 am
by ken99287
By the way, know anywhere to buy the fork if it's damaged?
