Make your own oil catch can
Posted: Mon Jun 09, 2014 3:28 pm
Disclamer: I take no responsibility for damage to your person, car, stuff, other people, other people's car or other peoples stuff. I must emphasize that ALL activities are done at your own risk.
Quick instructions
Long story short get a suitable sized jar that can withstand heat, oil, and vibration (preferably heat resistant plastic). Feed your pcv hose into the jar and then feed from the jar to the intake. For those of you that want more detailed instructions and specifications continue reading.
I am taking part in an Auto-CAD course in Highschool. For our culminating project each of us were given the task of designing and building an oil catch can. We tested a total of ten different designs. The following is a detailed description of how to build your own catch can, the concepts behind our designs and how well they performed during testing. P.S. This catch can is not meant to be pretty it is designed to work and be extremely cheap
How to Make
Tools/safety equipment
Drill
Hot glue gun
Safety glasses
Materials
Large jar at least 2†diameter preferably 4†(calculations for finding jar size at end)
Tubes ¾†ID (internal diameter)
Glue
How to make
1 First clean the jar making sure to remove all materials from the inside of the jar.
2 Second remove the lid and drill holes just large enough to get the tube into.
3 Then feed the tubes through the holes keeping one tube higher than the other but make sure to not push the tubes farther than 1†into the lid. This helps prevent the air coming into the can and then immediately leaving the can. The higher tube is where the clean air will leave the jar and the lower tube is where the oil filled air will be coming into the can.
4 Next glue the tubes in place both inside and outside of the lid.
5 Reattach the lid and you are done making the can.
Can attachment
To attach this can all you need to do is cut your pcv hose and feed your pcv hose into the jar and then feed from the jar to the intake.
Also make sure that the lid is securely fastened down.
You may want to add a dab of glue to make sure the lid does not come loose.
How we made and picked the best design
Safety equipment:
The first thing we must do is ensure we have all of the proper safety equipment. This should include the following.
Protective Glasses
Gloves if necessary
Long Sleeve shirt
Test Equipment:
Airline Lubricator
Model: Mettle Air AL 2000-02
Rated Flow: 800 L/min variable flow rate
Port Size: 1/4" NPT
Bowl Capacity: 〖25cm〗^3
Air Pump
150 psig 50 gallon air compressor
Connectors Tubes and Clamps
quick connecter
Weigh Scale
Acculab Vicon - accurate to within one one-hundredth of a gram
Procedures
Throttling
Air throttling
The air was throttled to approximately one-quarter maximum flow rate.
Oil throttling
The oil inlet was throttled to allow only partial flow of oil. This can be adjusted as needed in testing as long as all cans are tested with the same throttle rate.
Pressure used
150 psig
Duration of the test
1 min per can
Measuring oil caught
We measured the weight of the cans before and after the test. We then used the weight differential to determine the total amount of oil caught by the can.
Different designs
Tim’s Catch Can
The idea behind this catch can was that it would enable the catching of liquids in general and not be limited to oil.
Kendra’s Catch Can
The idea behind this catch can was that it is simple to make and extremely compact.
Jared’s Empty Big Catch Can
The idea behind this catch can is that it will slow the air below 1m/s which will allow gravity to remove the oil from the air.
To make this design I calculated the amount of blow by that would be coming from the engine. I then designed a can that would slow the air below the minimum m/s in a worst case scenario. (calculations at end)
Jared’s Electrostatic filter Catch Can
The idea behind this catch can was that it would filter the air by collecting the small particles of oil.
Jared’s Empty Small Catch Can
The idea behind this catch can was to provide a base to compare all the other catch cans too.
Jared’s steel wool Catch Can
The idea behind this catch can was to cause air turbulence which would increase the condensation rate.
Evan’s Catch Can
The idea behind this can is that the wire wool and other materials will act as a filtration system that prevents oil from escaping the can.
Sam’s Catch Can
The idea behind this catch can is that it will slow the air below 1m/s which will allow gravity to remove the oil from the air. It was also assumed that by adding an absorbing material in the bottom of the can that it would promote the collection of oil.
Results
Different cans and statistics
Tim’s Catch Can
Starting Weight - 265.7 g
Ending Weight – 267.1 g
Total amount of oil caught – 1.4 g
Kendra’s Catch Can
Starting Weight – 217.4 g
Ending Weight – 218.5 g
Total amount of oil caught – 1.1 g
Starting Weight – 217.1 g
Ending Weight – 223.6 g
Total amount of oil caught – 6.5
Starting Weight – 134.6 g
Ending Weight – 136.8 g
Total amount of oil caught – 2.2 g
Starting Weight – 128.3 g
Ending Weight – 133.5 g
Total amount of oil caught – 5.2 g
Starting Weight – 154.51 g
Ending Weight – 156 g
Total amount of oil caught – 1.49 g
Evan’s Catch Can
Starting Weight – 94.5 g
Ending Weight – 99.7 g
Sam’s Catch Can
Starting Weight – 101.92 g
Ending Weight – 103.56
Total amount of oil caught – 1.64 g
Compare
Best Design
Jared’s Empty Big Catch Can is the can that caught the most oil during the testing.
Reasons why it worked better
The reason it worked the best is likely because of its size. I found that in a worst case scenario that I would need a can that was two inches in diameter to allow the oil to drop out of the air naturally. I then designed this can to be twice the height and width. This gave the can seven times the volume of the other cans tested. I also used larger tubes to slow the entry speed of the air and reduce turbulence further slowing the air. Thus giving the oil more time to be pulled of the air due to gravity.
Conclusion
Does the can lower the amount of oil residue buildup in the engine.
yes
Were we successful in finding the best design for an oil catch can?
yes
Does the oil catch can meet all expectations?
yes
What are some ways that the design could be improved?
We could improve the design by angling the tubes to give a cyclonic effect thus utilizing not only gravity but also centrifugal force.
Recommendation
My recommendation is to obtain an oil catch can that does not contain any filter medium but rather has a larger interior space.
I would also recommend that the connecting tubing be of the largest diameter convenient so as to slow the air down before it reaches the oil catch can.
Calculations
These are the equations to find out the size of catch can you need for gravity induced oil collection.
In my case I have a 2.4 Liter engine. I am assuming 4000 rpm running speed. With 90 percent Volumetric efficiency which means although I have a 2.4 Liter engine I am assuming it is only taking in 2.16 Liters of air. I am assuming a worst case scenario of 3% blow by (air escaping into the crank case). The equations for this scenario are a rough estimate to determine what size of catch can you will need. Feel free to change the numbers in the equations to fit your particular car.
S=Engine Displacement (in liters)
N=engine speed (in RPM)
VE=volumetric efficiency
V=volume of blow by (in liters per minute)
S=2.4 L
N=4000 rpm
VE=90%
Blowby rate=3% (0.03)
V=(N*S*VE)/2*Blowby rate
V=(2.4*4000* .90)/2* 0.03
V=129.6 Liters per minute
A=cross sectional area of catch can (in m^2) Vb=blow-by volume (in liters per minute) Vc=Critical speed for oil drop out (in meters per second)
A=(Vb*0.0000167)/Vc
A= (129.6*0.0000167)/1
A= 0.00216432 m^2
D=diameter of circular volume (in mm)
D=1000* √(4 *A)/π
D=1000* √(4 *0.00216432)/π
D=1000* √(0.00865728)/π
D=1000* √0.00275569781146120730489048405394
D=1000* 0.05249474079811431267117455923545
D=52.5 mm
I then made my catch can with double the diameter just for good measure.
Quick instructions
How to Make
Drill
Hot glue gun
Safety glasses
Materials
Glue
How to make
Can attachment
Safety equipment:
Protective Glasses
Gloves if necessary
Long Sleeve shirt
Test Equipment:
Airline Lubricator
Port Size: 1/4" NPT
Air Pump
quick connecter
Weigh Scale
Procedures
Throttling
Air throttling
Oil throttling
Pressure used
150 psig
1 min per can
Different designs
Tim’s Catch Can
Kendra’s Catch Can
Evan’s Catch Can
Sam’s Catch Can
Results
Tim’s Catch Can
Kendra’s Catch Can
Evan’s Catch Can
Sam’s Catch Can
Compare
Best Design
Conclusion
yes
yes
yes
Recommendation
Calculations
S=2.4 L
N=4000 rpm
VE=90%
A=(Vb*0.0000167)/Vc
A= 0.00216432 m^2
D=1000* √(4 *A)/π
D=52.5 mm
